AFM, MAFS, air meeeeeeeter
9 replies to this topic
#1 brian
brian
    I♥1J VVT-i
  • Root Admin
  • 4253 posts
  • Powered By:2JZGE, Cummins-5.9, Caffeine, Alcohol, 5VZ-FE
Posted 27 February 2009 - 12:51 PM
OK so I was talking with Mark about this a few nights ago, but I figure I'd ask here too. JZX100/LS400/GS400 uses a 3" MAFS (22250-50060) and JZA80 uses 3.25" of the same type (22250-46030). I found a local Supra version for $75 so I decided to get it instead.
I am kinda new with MAFS, so can I use a SAFC (first version) to correct for the larger MAFS or do I even need to worry about it?
"Don't bother messaging me if you ugly, cocky, trashy or not in the age range of 31-39" -andreakm26
#2 Guest_DuaxMachine_*
Guest_DuaxMachine_*
Posted 27 February 2009 - 03:17 PM
Yes, you can use the S-AFC to correct the difference.
Always tune by the readings from a good A/F meter.
('good' does not include anything that just reads 'rich' to 'lean')
Something that shows actual a/f ratio numbers,
like a TOMEI, or a GReddy like I have listed on eRip.
#3 brian
brian
    I♥1J VVT-i
  • Root Admin
  • 4253 posts
Posted 27 February 2009 - 08:24 PM
i picked up the supra mafs today and compared it to the jzx100 mafs, they're exactly the same.
nevermind. :lol:
#4 driftaholic
driftaholic
  • 824 posts
Posted 27 February 2009 - 09:05 PM
even if the supra was the same sensor in a larger body it would just lean you out a little and with a rich as toyota tunes you would prob only benifit lol
#5 MADMIKE
MADMIKE
  • 22 posts
Posted 27 February 2009 - 09:19 PM
The sc400 97+ uses the same as vvti also.
#6 brian
brian
    I♥1J VVT-i
  • Root Admin
  • 4253 posts
Posted 27 February 2009 - 09:43 PM
Any car with the VVTi 1UZ between 95-98 used the 22250-50060 MAFS
Same with the 96-2000 JZX100 VVTi 1JZ
94-98 Supra used a 99% identical MAFS. Its exactly the same dimensions and plug type. The only difference I see and maybe the reason for the P/N difference is the cross hairs on the intake of the "mafs torpedo" as I call it.
1UZ/1JZ has them, 2JZ doesn't.
It will work.
#7 TougeCrameryRollinNice
  • 696 posts
  • Country:Nigeria
Posted 30 December 2009 - 06:40 PM
does that mean i can get this? cause the maf on it looks totally different? if it fits then i want it. its from a 93-98 supra. part number 22204 46010 it does look smaller in diameter though:( maybe its not good.
JDM VIPness
#8 MX83MISSILE
MX83MISSILE
  • 314 posts
  • Interests:turbo cressida
Posted 31 December 2009 - 02:41 AM
I just did a 2jz-gte vvt-i and didn't have the afm witch was like this one so I used a afm out of a 99 GS300 and it worked fine .
mx83 cressida 1jz-gt vvt-i 5spd
fx16 20v 5spd
Pete, MX83MISSILE
#9 brian
brian
    I♥1J VVT-i
  • Root Admin
  • 4253 posts
Posted 16 February 2013 - 06:58 PM
ttt - good info
#10 TeckniX
TeckniX
  • 153 posts
Posted 09 September 2014 - 03:01 PM
Anyone got the actual pinout of the MAF sensor?
Left to Right - Female plug is facing you
1. Black/Red  - POWER
2. Green/Black - VG - Airflow ouput
3. Red/White - THA - Temp output
4. Brown - Common Sensor ground
5. Light Green - EVG - Airflow Ground
Looking at this picture the wires would be reversed if we went also left to right:
5. Black/Red  - POWER
4. Green/Black - VG - Airflow ouput
2. Brown - Common Sensor ground
1. Light Green - EVG - Airflow Ground
"Never argue with an idiot; they'll drag you down to their level and beat you with experience"
