475 replies to this topic
#1 LUMBERZACK
LUMBERZACK
  • 353 posts
  • Powered By:7MGE, Dicks
Posted 12 July 2017 - 05:13 PM
What's up dad fuckers?
You've made it this far, you might as well continue reading. This will be my piss poor attempt at a mediocre build thread.
Be forewarned, you most likely won't find any groundbreaking discoveries in this thread. This will likely be your run of the mill standard 2JZ-GTE swapped X8. I plan on doing cool shit and tailoring the car to my style, but I won't be doing anything extraordinary such as: 4-link rear end, highest hp Cressida, ultra drift star, chop top, cressi-truck, or any other outlandish idea you can think of.
This is not to say you won't find enjoyment from this build thread, because I know I will.
Background:
My name is Zack, a recent university graduate residing in Arizona. I come from a background heavily consisting of Subarus. My first car was a Subaru STi that I have driven the last 7 years and I still own. I picked up my 1990 Cressida two years ago as a daily driver that I knew I would begin to modify. Subaru parts are very pricey, so I bought the Cressida as a cheaper way to feed my fix for modifying cars.
In the 2 years I have owned the Cressida, I have accomplished quite a list of things that I didn't envision doing over this period of time. This was all due to unforeseen circumstances that lead me to forego the aforementioned expenditures.
I purchased the Cressida as a rough car that needed TLC, but had plenty of potential, in my eyes. It didn't start, I was told it needed a starter, a clutch, and a battery. I sent the guy the money, he gave me the paperwork and keys, and I had a tow truck arranged to drop the Cressida off at my house.
Parts list as of 8/13/18:
Engine
1997 JZS161 VVT-i 2JZ-GTE ECTS-i
Borg Warner S257sx-e 1.0 A/R T4 twinscroll
Future Fab twinscroll T4 manifold
Tial MVS 38mm external wastegate (x2 conspiracy theory)
Tial QR BPV
Fluidampr Harmonic Balancer 840801
NGK (4589) IFR6T-11 laser iridium spark plug
Panic wire harness to GS300 ECU box
1994 MK4 Supra water temp sender
XM S10 25" Power steering line
XM JZ/Kouki engine bracket
XM engine mount
Custom straight piped turboback to a HKS Hi-Power muffler w/ Ti tip (34005-FK001)
OEM Toyota MK4 Supra throttle cable
K&N 3" pod air intake
Driftmotion universal intercooler kit
Driftmotion pulley kit for alternator/power steering/water pump
SC300 2jz Denso A/C compressor (88320-24120) w/ 7M compressor manifold
Dayco poly-rib 2JZ serpentine belt w/ power steering and a/c
2JZ timing belt
OEM Toyota MK4 Supra mechanical water pump (16100-49847)
OEM Toyota thermostat
Greddy magnetic oil drain plug
Koyorad N-Flo aluminum radiator for JZX100
IS300 radiator fans/shroud & coolant reservoir
OEM Toyota seals (cam/water pump/VVTi cam gear/rear main/front main)
GSC Viton Valve seals
Greddy water temp sensor attachment
Blitz Oil sensor attachment sandwich plate
MK4 Supra check valve for brake booster
IS300 Power steering pump
Chasebays power steering reservoir
PHR power steering pump AN conversion fitting
Power steering AN conversion
OEM coil pack connector plugs
OEM Toyota exhaust gasket
AZ Performance AN oil drain flange
Denso Narrowband sensor conversion for Aristo
OEM VVT-i oil control valve
Fuel
Denso fuel pump from Toyota Aristo (GTE)
Earl's hard line to AN-fitting adapter
Earl's fuel filter
Parker Store custom braided fuel line with AN-fittings
Driveline
MK3 R154
OS Giken TR2CD twin disk & flywheel
OS Giken movement alteration kit
OS Giken JZ flywheel bolts
Nachi Pilot Bearing
OEM Toyota JZ/R bellhousing (31111-14111)
OEM Toyota Speedo cable and cable elbow
XM series 2 clutch line 53"
XM JZ/R one-piece driveshaft
3.2 qts Redline MT-90
Differential
MK3 Supra differential LSD
Rebuilt by Ken Francisco of GearInstalls
Weir stage 2 max-grip kit
Weir solid pinion spacer
3.9 ratio ring and pinion
OEM Toyota diff seals and Koyo bearings
OEM Toyota diff breather check valve
OEM Toyota magnetic drain plugs and crush washers
1.2L Motul 75w-90 synthetic gear oil w/ LSD additive
XM diff conversion kit (modified by Marc at BuildRadStuff)
XM rear subframe reinforcement plate
Suspension
Fortune Auto 500 Gen 7 coilovers. 20mm shorter shock bodies. 6" Swift springs. 15k Front/ 10k Rear.
Fortune Auto LCA-mount conversion front endllinks
XM adjustable rear arms
XM front tension rod bushings
XM rear lower pillow balls
XM rear traction rod pillow balls
XM RUCA bushings
XM Rear subframe bushings
MR2 18mm front sway bar repurposed for rear sway bar
Xcessive heim endlinks
XM steering rack bushings + x7 conversion
MX73 steering rack
20mm forward steering rack relocation
Proforged MX83 driver side inner tie rods
Brakes
Sumitomo 300zx 300mm aluminum 4-pots front.
Standard pads and rotors
StopTech Braided SS brake lines
Project Mu D1 spec e-brake shoes
Exterior
Custom two-tone paint scheme (Champagne/Bronze)
Black side mirrors and door frames
R-M Diamont Base Coat
SPI Universal Clear Coat
Shaved radio antenna
Engine bay sprayed champagne with sahara gold flake (0.015)
Custom bash bars F/R made specifically for BIG☆WIN kit
Authentic BIG☆WIN JZX81 Mark II Type-SP F/B body kit
JZX100 turn winkers
GX81 Mark II sedan headlights with integrated fog lights.
GX81 Mark II sedan grille
Australian MX83 series 2 corner lights
Australian MX83 series 1 boot lock
Australian MX83 chrome door handles
Rickyy's DM aero replica roof wing
SerialNine Type-1 rear bumper
SerialNine Yamaha Wing
Sylvania LED bulbs
R33 Nissan GT-R wheels 17x9 +30
Achilles ATR Sport 2 215/45R17
Interior
Defi BF-Advanced controller and gauges (Turbo, Water Temp, Oil Temp, Oil Pressure)
AEM X-series 30-0300 A/FR gauge
MK3 Supra brake pedal
MK3 Supra clutch pedal w/ reservoir
Tom's steering wheel w/ Tom's horn button
Bride Zeta 3 Japan (black suede/ super aramid carbon shell)
Bride FO seat rail (MX83/JZX81)
TRD Sports AE86 option reclining bucket seat w/ custom bracket
Pioneer headunit
Pioneer speakers
Sylvania LED bulbs throughout
Clear door markers
Garage Moon Power HKS-style floor mats
Toyota Starlet fog light switch to control GX81 fogs. (Kit made by 'Boristhecat')
Battery relocated to trunk w/ circuit breaker
JZX81 spin turn drift knob
Progress pictures to follow..
#2 LUMBERZACK
LUMBERZACK
  • 353 posts
Posted 12 July 2017 - 05:17 PM
Since I bought the car without being able to start it, I was taking a leap of faith and putting a lot of trust in the seller's honesty. Overall I am not disappointed in the car that I bought although there were more issues with the car than I anticipated.
To list Cons:
The car didn't start, the car needed a battery, and the clutch wouldn't disengage. After fixing those issues and driving the car, I came to find out:
The Problem - My Solution
The key I had only worked on the driver lock and ignition, the trunk lock and passenger lock didn't match - Rekeyed all of the locks
Cracked windshield - Replaced windshield
The hazards didn't work - found out there was no fuse
The horn didn't work - was on same fuse as hazards
The wipers didn't work - Wiper control module was fried
No power locks worked - Needed new motors
The tachometer/fuel level and engine temp didn't work - same ground not bolted to chassis
The interior illumination lights didn't work - no fuse
Fuses panel had different amp fuses than what was specified - fixed per vehicle specs
No antenna - picked up at junkyard
No cupholders - bought from a member
Fuel door was cock-eyed - Broke it, rewelded it, miraculously centered itself
Missing footwell covers - picked from a Cressida part out
Missing mirror adjustment knob - picked from a Cressida part out
Broken arm rest latch - picked from a Cressida part out
Cracked interior door handle insets - picked good condition from a Cressida part out
Missing interior bolts everywhere - picked up a bunch from a junkyard Cressida
Weather strips were too far deteriorated - picked up a good set
Broken sun visors - bought from a member
Radio didn't work - installed new head unit
Steering wheel wouldn't zero out (rack was moving) - XM rack bushings
Braking would cause a variant of death wobble - New brakes and suspension
Suspension was bouncy and shot - New suspension
No hood struts - bought hood struts
A/C didn't work - Does now
W58 didn't have a shift boot, allowing air and fumes from the exhaust leak at the header to enter the cabin - R154 has boot
Drive axle boots had disintegrated - bought new axles
Carrier bearing rubber disintegrated and 2 piece driveshaft flexed and clunked - I went one-piece
Engine leaked oil and threw a rod in 5,000 miles - swapped it
Paint was shit - Painted it
Considering all of this, I'm happy with the car because it is a clean body, matching VINs and rust free. It's 25 years old and I wouldn't expect everything to work flawlessly. If it all worked, it wouldn't have been for sale for how cheap it was.
These pictures are spanning the time frame of the first time I saw the Cressida in person, to when it first landed in my driveway in 2015.
#3 LUMBERZACK
LUMBERZACK
  • 353 posts
Posted 12 July 2017 - 05:20 PM
Obligatory first step of car ownership is a good cleaning.
#4 LUMBERZACK
LUMBERZACK
  • 353 posts
Posted 12 July 2017 - 05:22 PM
Addressing the issue of replacing the starter and investigating why the clutch doesn't work.
#5 LUMBERZACK
LUMBERZACK
  • 353 posts
Posted 12 July 2017 - 05:26 PM
Now I see why the clutch didn't work. 4 of the 6 flywheel bolts I was able to spin with my hands and one was backed out so far that it was contacting the clutch disk. Shitty snapchat quality pic.
#6 LUMBERZACK
LUMBERZACK
  • 353 posts
Posted 12 July 2017 - 05:27 PM
First drive with my "new" Cressida
#7 LUMBERZACK
LUMBERZACK
  • 353 posts
Posted 12 July 2017 - 05:30 PM
Not much of a head unit, but it has Bluetooth and a USB charger. ¯\_(ツ)_/¯
#8 LUMBERZACK
LUMBERZACK
  • 353 posts
Posted 12 July 2017 - 05:31 PM
Some classic era correct goodies from Japan.
#9 LUMBERZACK
LUMBERZACK
  • 353 posts
Posted 12 July 2017 - 05:36 PM
By this time my 7m had acquired rod knock in the short 5,000 daily driven miles that I put on it. I began preparing for a 2jz swap. I picked up this JZ/R flywheel and R154. My Cressida came 5-speed swapped with a w58, but I did not want to put that trans behind a GTE.
#10 LUMBERZACK
LUMBERZACK
  • 353 posts
Posted 12 July 2017 - 05:40 PM
Ripping out that disgraceful 7M and indulging in some much needed spring cleaning. I wish I had more photos of the stock engine bay to display how oily and covered in gunk the engine and bay were. You could hardly tell what engine it was as it appeared like a black lump.
#11 LUMBERZACK
LUMBERZACK
  • 353 posts
Posted 12 July 2017 - 05:42 PM
Meticulously picking out my new engine from a local importer "JDM Hotline" in Arizona and bringing her home.
They did a dry compression test with my presence and the engine showed right about ~160 psi across the board. No oil was present in the charge piping or seeping out of any crevices, so it appeared to be a clean, strong unit.
#12 LUMBERZACK
LUMBERZACK
  • 353 posts
Posted 12 July 2017 - 05:44 PM
Awesome P-N-P swap service provided by the legend himself, Mark Panic. Great guy, great service. 10/10 would recommend.
#13 LUMBERZACK
LUMBERZACK
  • 353 posts
Posted 12 July 2017 - 05:48 PM
I stayed fairly conservative with this swap. I didn't go all out. I replaced typical maintenance items such as water pump, thermostat, timing belt, tensioner, pulleys, serpentine belt, various gaskets, seals, and spark plugs.
I didn't want to do too much as I wanted to verify the engine and swap was a solid platform to modify as I wasn't 100% sure the condition my engine and r154 were in. I played it safe for the time being.
#14 LUMBERZACK
LUMBERZACK
  • 353 posts
Posted 12 July 2017 - 05:52 PM
SC300 A/C compressor fitted. Arizona summers are fucking brutal, so this mod is a must. I used the 7m compressor manifold fitted to the SC compressor to allow me to utilize the factory Cressida lines. I had to perform a bit of grinding to the PS bracket to accommodate for the manifold lines.
#15 LUMBERZACK
LUMBERZACK
  • 353 posts
Posted 12 July 2017 - 05:55 PM
Putting everything all back together, preparing to drop the whole thing in.
#16 LUMBERZACK
LUMBERZACK
  • 353 posts
Posted 12 July 2017 - 05:57 PM
It fits.. As it comes of no surprise at all.
#17 LUMBERZACK
LUMBERZACK
  • 353 posts
Posted 12 July 2017 - 06:01 PM
Just the standard DM universal intercooler kit.
#18 LUMBERZACK
LUMBERZACK
  • 353 posts
Posted 12 July 2017 - 06:03 PM
I used the Aristo GTE denso fuel pump that came with my 2JZ in place of the stock fuel pump.
#19 LUMBERZACK
LUMBERZACK
  • 353 posts
Posted 12 July 2017 - 06:05 PM
By this time it has been running and driving. I took it to a buddy's shop to get the A/C charged. Ice cold as usual.
#20 LUMBERZACK
LUMBERZACK
  • 353 posts
Posted 12 July 2017 - 06:09 PM
I was driving the car open downpipe up until I bought this HKS Hi-Power muffler and had a straight 3-inch pipe made to it. Surprisingly the open downpipe was very tolerable. I assume the twin turbos muffle and quiet the sound of the engine quite a bit.
