What gear oil is best for R154?
  • This topic is locked This topic is locked
52 replies to this topic
#1 Guest_OrlandoGTE11211_*
Posted 23 August 2012 - 02:43 PM
Soon I'm going to be changing up my clutch and was curious to what fluid everyone prefers in their r154,I seen red line on DM but I figured I'd ask here before I order anything.
#2 Kyle
  • 6614 posts
Posted 23 August 2012 - 04:33 PM
I wanna say 80w-90 is what it calls, for but honestly can't remember. I do know it calls for 3.2 qts
#3 bwcress
bwcress
  • 1187 posts
Posted 23 August 2012 - 05:23 PM
I run redline mt90 thats shit is the beezkneez
#4 Guest_OrlandoGTE11211_*
Posted 23 August 2012 - 06:30 PM
Did the redline make a big difference from what was in there before? And good looks on the quarts because I had no idea how much it takes,so I need to get at least 4 Qts.Wouldn't hurt to have left overs.
#5 Guest_Mitto_*
Guest_Mitto_*
Posted 24 August 2012 - 05:08 AM
Redline and redline only.....
Once I rebuild my R154 thats whats going in mine.
#6 ChriSOL
  • 6954 posts
Posted 24 August 2012 - 05:18 AM
at work we use redline shock proof. holy balls this stuff is awesome. it's opaque and turqoise in color and STICKS to everything. you'd probably be able to get away with the standard 80w90 or 75w90 for daily street use but i'd switch to that if i drifted or road raced my car. i've seen firsthand the benefits of using it in our webster and hewland transmissions.
#7 Guest_swim_*
Guest_swim_*
Posted 24 August 2012 - 09:59 AM
D:
#8 ChriSOL
  • 6954 posts
Posted 24 August 2012 - 10:18 AM
we use the lightweight. that looks like superlight which i have no experience with. i've torn down or watched several gearboxes being town down that have run it hard under race conditions and high input shaft rpms for hours and they always wipe away clean with a shop towel. no residue ever, and no signs of burning or loss of viscosity. i can take pics next time im inside one of the boxes before during and after running through the parts washer.
#9 Guest_swim_*
Guest_swim_*
Posted 24 August 2012 - 11:09 AM
huh. I've just heard that lightweight and heavyweight shockproof can gunk up like that when used for extended periods of time in roadgoing gearboxes
on track cars and the like where the transmissions are being constantly being rebuilt and cleaned out, it's great, but supposedly in street cars you stand a chance of the pictured stuff happening. fuck if I know, though.
#10 ChriSOL
  • 6954 posts
Posted 24 August 2012 - 11:18 AM
we use rotary engines in our race cars. unlike a lot of the other piston engined cars i've worked around (formula enterprise and atlantic) they don't require rebuilding that often unless the driver is hard on them. our shop cars get driven for an average of 12-18 hours a week (if you added up the time my miata is being driven on the road it's probably about the same if not less) and spend a lot of time just sitting between sessions or on off days. i'd say that is pretty close to the way i drive my miata (not a lot of power, rev the piss out of it at every opportunity). i am going to run this stuff in my transmission the next time i have a chance and i will let you know how it does on the street.
i'll probably end up leaving it in there for at least 6 months and i'll check it out after.
im not arguing, just sharing personal firsthand experience.
#11 Guest_Lofty_*
Guest_Lofty_*
Posted 24 August 2012 - 11:44 AM
I use Syncromesh in my drag car. Has anyone tried it on our transmissions? AFAIK it's GL4 and GL5 compliant.
Either that or Redline anything, can't really go wrong with it. I mix redline heavyweight MTL and syncromesh on my car, but I've got no idea about w58/r154s.
#12 DiscoShit
DiscoShit
  • 1186 posts
Posted 24 August 2012 - 09:02 PM
i ran lightweight shock proof in my mr2 e153 and my cressida r154 and it was great on both.
#13 Kyle
  • 6614 posts
Posted 25 August 2012 - 04:46 AM
I had wondered about syncromesh as I had use to run it in a tremec I had in a foxbody. put it in your car and let us know lofty. we need to know
#14 Guest_JerryCan_*
Guest_JerryCan_*
Posted 25 August 2012 - 08:59 AM
I used Redline one time in an old Datsun 510 5-speed, and it was too slippery for the syncros to work.
Trans shifted fine with normal gear oil, but when the Redline was put in, it was almost impossible to shift.
Drained the trans, and put normal oil back in, and it shifted better, but still had problems.
Changed the oil again, to get all traces of the Redline out, and the trans was fine again.
Maybe it was the older design trans, or the design of the Nissan syncros, but it sure didn't like the Redline.
#15 Guest_OrlandoGTE11211_*
Posted 25 August 2012 - 11:24 AM
I used syncromech and dex 6 in my camaros t56 it worked wonders,shifted way smoother.I am defiantly going to go with redline though. Thanks for the advice everyone.
#16 Guest_JerryCan_*
Guest_JerryCan_*
Posted 25 August 2012 - 01:34 PM
Well, been surfing, and may have found why the Redline didn't work well in the old datsun.
I have found several refferences to the fact that you should not use a GL5 oil in anything with 'Yellow metal' syncros, as it is too slippery, and will also corrode them.
GL-4 only.
So after I get my w58 back together, I will go with some Red Line MT-90 GL-4, maybe with a little shock-proof mixed in.
#17 JoeTheHook
JoeTheHook
  • 719 posts
Posted 25 August 2012 - 04:19 PM
redline mt90 Night and day difference.
#18 Guest_Lofty_*
Guest_Lofty_*
Posted 25 August 2012 - 05:58 PM
Alright, I'll throw it in my w58, not even fucking around.
Let's do this shit.
I'll make a thread about how it works.
#19 Guest_swim_*
Guest_swim_*
Posted 26 August 2012 - 01:37 AM
in Subaru transmissions, five and six speed alike, the synchros are yellow metal, but you should use a GL-5 compliant oil to not explode the hypoid gears for the front differential. what I came up with for that, and what I got my friends to use, was two quarts of MT90 with 1.7 quarts of 75W90NS on top. everyone that tried it loved it. on both my 5-speeds, I was able to heel-toe into first at 20mph, a feat which may be impossible depending on the oil you're using. couldn't've had anything to do with wear, since my piece of shit stock transmission which stripped 2nd gear clean of it's teeth at 140k was always able to do it since I switched to the redline blend.
I don't know if our synchros are yellow metal or not, but I'm definitely planning on running either MT90 or a mix of MT90 and a shockproof oil, if shockproof is safe to use.
#20 Guest_Lofty_*
Guest_Lofty_*
Posted 26 August 2012 - 11:01 AM
"Heel toe into first at 20mph"
Why would you even feel the need to do this? Thats how transmissions are ruined lol.
