Project Hantavirus
209 replies to this topic
#201 hantavirusx8
hantavirusx8
  • 114 posts
  • Powered By:1JZGTE, Caffeine, Alcohol
Posted 16 February 2017 - 06:00 PM
TRD 2 way is in and amazing. I haven't heard a noise from it. Super smooth and predictable lockup.
received_1458836904150754_zpstmvaopbn.jp
I forgot to mention I used an SW20 MR2 booster to clear the FFIM. Straight bolt in.
Also got a trailer so I can tow to events! Picked it up in rough shape for $700. Sanded down and painted with POR15, sanded the deck and resealed it, greased wheel bearings, fixed wiring, new tires, new lights, and new jack. Now I'm just counting down the days until PARC and hoping it's dry and not a muddy shitshow
16729200_1488761481158759_59053451150320
#202 shlammed
shlammed
  • 457 posts
Posted 16 February 2017 - 06:10 PM
Looks good. Have you tried that brake booster yet? Interested to know if it gives the same amount of assistance.
#203 hantavirusx8
hantavirusx8
  • 114 posts
Posted 16 February 2017 - 06:13 PM
Yeah I've been driving with it for months. It's hard to say but it feels like it has maybe 70% of stock assist. The brakes feel more "direct" and still have plenty of power to lock up if needed
#204 Billyhoo
Billyhoo
  • 321 posts
Posted 16 February 2017 - 07:03 PM
Good find!
Freedengineering.com
#205 Kyle
  • 6606 posts
Posted 17 February 2017 - 06:18 AM
Killin it
#206 hantavirusx8
hantavirusx8
  • 114 posts
Posted 21 April 2017 - 07:59 PM
I saw a couple people were using the 2UZ Tundra 130A alternator so I decided to give it a shot. I grabbed an 04 Sequoia alt which is a 150A, hairpin stator. Cut one mount down, cut another mount off, change the plug and you're good to go. Night and day difference from the stock alt. Maintains 14V at idle with everything on.
18052924_1562586360442937_601464806_n_zp
18083666_1562586307109609_1624192492_o_z
Aligned today
18110243_1562586150442958_244082217_o%20
I might go to PARC on the 30th, anyone going?
#207 Andrew
Andrew
  • 450 posts
Posted 22 April 2017 - 11:57 PM
More about this sequoia alternator.
#208 hantavirusx8
hantavirusx8
  • 114 posts
Posted 24 April 2017 - 07:46 AM
Got it from B&R auto wrecking for $71. Pulley is the same. Uses a common toyota or honda square alt plug. I slipped it on over the bottom stud and marked the top mount where it needed to be trimmed and cut it down slowly until it aligned with the other pulleys with a straight edge. Apparently hairpin stator alts are a newer design that run cooler and charge better at idle
#209 Demesio
Demesio
    I♥VTEC
  • 1225 posts
  • Country:China
Posted 24 April 2017 - 08:19 AM
That's only 10AMPS more than the alternators that come on the vvti engines...
#210 hantavirusx8
hantavirusx8
  • 114 posts
Posted 24 April 2017 - 09:02 AM
I can load and clamp the JZ, JZ vvti and sequoia alts if you guys are really interested but the sequoia alt is significantly stronger from what I've seen
