open-element IAT sensor for 1JZ/2JZ
IAT Sensors standalone
31 replies to this topic
#21 Kyle
  • 6606 posts
Posted 02 December 2012 - 06:17 AM
I'm guessing 92ish? I'd like to try this on the emanage.
#22 Gaijin Smash Wayhoff
    Fellate Me
  • 1246 posts
  • Interests:"Excessive quotation marks"
Posted 17 August 2013 - 07:31 AM
Any update on this?
#23 DiscoShit
DiscoShit
  • 1186 posts
Posted 17 August 2013 - 07:36 AM
Yea 92ish. Turbo mr2s have that same iat sensor on the engine lid. Car uses it to turn on the intercooler fans. I also used it when I wired the stock 3s harness to run the newer gen ecu that uses map and iat.
#24 Kyle
  • 6606 posts
Posted 17 August 2013 - 08:18 AM
Disco mr2 is same as Gte gen 1 that screws into the intake? Or as the corolla style that's plastic and is designed for the intake tract? Gameface I believe just wired in a gm unit and said fuckit.
#25 DiscoShit
DiscoShit
  • 1186 posts
Posted 17 August 2013 - 09:28 AM
Usd mr2 was always maf so it only had the plastic one as a thermostat for the intercooler fan. The maf had the iat for the ecu built in. The 3rd gen and on 3sgte used the 2, the screw on one on the manifold and the plastic one on the intake. Dont know why Both. But they both use the same resistance across different ttemps.
#26 Lofty
Lofty
    MOTOBYTE.NET
  • 1948 posts
  • Country:South Africa
Posted 09 August 2017 - 12:09 PM
Bumping this.
Has anyone used the stock IAT and just welded a bung for it into the FMIC piping?
I have greddy emanage ultimate and I'm trying to figure out if i should go GM IAT  or try to find a ???M16 x 1 . 5 ???? bung for the stock IAT?
Straight up though...Cressida=Home wrecker 9000
http://tmzperformance.com
#27 Gordo
Gordo
    Resident Grumpy Old Man
  • 6846 posts
Posted 09 August 2017 - 12:43 PM
An AIT is an AIT......
It's just a thermistor.
Back when HKS VPCs were a big seller, I was making my own using thermistors from an electronics house, and a machined phenolic/aluminum housing.
But just about any Toyota one should work.
And the HKS IAT has a very small M6 thread, and I think are just $60.
Prefixes for 'Gordo'
口 Holy Shit
口That ass hole,
口The Magnificant
口That old fart,
口The infamous
口That crazy
口That 7M guy,
#28 Lofty
Lofty
    MOTOBYTE.NET
  • 1948 posts
Posted 09 August 2017 - 01:14 PM
The one I have is too fuckin big. And I hear the GM IAT one reads differently. So not sure how an IAT is an IAT unless I misread.
#29 Gordo
Gordo
  • 6846 posts
Posted 09 August 2017 - 02:08 PM
It may.
But if dealing with a stand-alone, it doesn't matter, as that is all definable.
If dealing with an oem ecu, just have to check resistance at freezing (ice water), and boiling water.
Or as I suggested, just use any Toyota unit, as they are most likely the same range.
The old 7M flapper meters have one held in with a single screw, and quite compact.
口 Holy Shit
口That ass hole,
口The Magnificant
口That old fart,
口The infamous
口That crazy
口That 7M guy,
#30 slapsticksammy
slapsticksammy
  • 170 posts
Posted 11 August 2017 - 02:21 PM
You could buy a m16 to 1/8 npt adapter. I bought an AEM 1/8" NPT AIT. It doesn't nearly stick out far into the air stream. I also ended up over tightening it and snapping it in half.
#31 Demesio
Demesio
    I♥VTEC
  • 1242 posts
  • Country:China
Posted 11 August 2017 - 04:32 PM
hahaha yes, make your own bung...
#32 Gordo
Gordo
  • 6846 posts
Posted 11 August 2017 - 05:45 PM
hahaha yes, make your own dung...
Fixed.
口 Holy Shit
口That ass hole,
口The Magnificant
口That old fart,
口The infamous
口That crazy
口That 7M guy,
2 user(s) are reading this topic
    Google (1)
