r154 trans issues
22 replies to this topic
#21 Demesio
Demesio
    I♥VTEC
  • 1458 posts
  • Country:China
Posted 03 October 2018 - 04:51 AM
AR5 are close to the R154, but cant take anything over 400whp.
If any of you still have stock r154s, I'd recommend Redline heavy shockproof...
#22 timtiminy
timtiminy
  • 59 posts
  • Interests:Outdoors, fitness, health. Bicycles, running, rock climbing.
Posted 03 October 2018 - 09:30 AM
Gordo, aren't you running like a 5.29 in the rear?
I would assume you're running a t56 for the tall first gear?
Its only a 5mph difference topped out in 1st between the AR5 and R154.
I liked the closer ratios on the AR5, meh.
Could run the factory 3.9 gear ratio and still have a faster 60ft time than a 4.3 R154.
I have a 4.3 supra diff though and a low power na 2jz, I think that'll be more fun.
I'll keep the 3.9 if I turbo it down the line.
#23 Gordo
Gordo
    Resident Grumpy Old Man
  • 7444 posts
Posted 03 October 2018 - 10:57 AM
I was running 4.56 on the street, and the 5.3s at the Texas mile, but I turn way more RPM than you will ever do.
And that was with an auto, which typically use deeper gears.
(a little history: the HKS drag MkIII ran 5.3 gears behind a powerglide, but turning 10k).
Now I have an HPI 6-speed, with a 2.9 first, and a .86 6th.
With 3.9 gears, top end will be about 175, about the same as what I had.
And with a twin plate Tilton/Quartermaster/Borg-Beck 7-1/4" clutch, on a 7lb flywheel, with the 2.9, it will beyond most men, and all women to actually get the car rolling without doing a 8k clutch dump.
Had bought a T56, and then sold it off after I realized I fucked up buying anything with that lousy of a ratio spread.
But that was back in the day I was going to do a blower, and make grunt, not speed.
I really don't understand the AR/T56/CD009 crap, with those ratios.
A better choice would be one of the newer T600 5-speeds, as they can be had with a good ratio spread that would work with you guy's low boost, early spool thinking.
But wait....
They cost 2k...
Prefixes for 'Gordo'
 口 Holy Shit
口That ass hole,
口The Magnificant
口That old fart,
口The infamous
口That crazy
口That 7M guy,
Best JZXP statement:
