MX83 to MA70 Differential Conversion Kit
3 replies to this topic
#1 lucas
lucas
  • 1559 posts
  • Interests:$$$
Posted 31 January 2013 - 07:28 PM
If your looking to swap an MA70 Supra (MK3) differential into your MX83 Cressida, this is the kit you need to line things up. We've made this weld in kit with the front mounting points already welded to a reinforcing base plate and the correct height and spacing for the MA70 to MX83 conversion as well as set it up for bottom up bolting so you won't have to do the top down problem of the MX83 type differential. We've also supplied our stud mount solid rear bushings to get everything held tight and located.
You will need to use your rear cover from the MX83 differential to mount the MA70 in the Cressida sub frame.
[color=rgb(255,0,0);]This is not a bolt in kit. You will need to weld on the new front mounting points and replace the the stock rear bushings. The stock MX83 differential will not bolt back in once the front modification has been welded in.[/color]
Price: $ 164.00/kit  ---------------------------------> MX83 to MA70 Differential Conversion Kit
Justin
Get in touch with me for MX83 body kits
For a everything Cressida:
Xcessive Manufacturing
Phone: 1-503-504-2147
#2 BKCressida1718
BKCressida1718
  • 197 posts
  • Country:Saint Vincent and the Grenadines
Posted 31 January 2013 - 09:28 PM
I notice that this has only to solid diff bushings as opposed to the four that comes with the kit for the stock diff. I haven't used my bushings i got for the stock diff yet. Can I use them for the LSD diff while using this kit?
#3 lucas
lucas
  • 1559 posts
  • Interests:$$$
Posted 01 February 2013 - 09:04 AM
the rear bushings are the same between the two. If you already have bushing for the OEM differential get in touch with XM regarding pricing for the MA70 supra differential kit.
Justin
#4 BKCressida1718
BKCressida1718
  • 197 posts
Posted 01 February 2013 - 11:38 AM
thanks.
