Pearly whites and black metal
378 replies to this topic
#361 Billyhoo
Billyhoo
  • 331 posts
Posted 04 June 2017 - 08:58 PM
Hah, I used to dumpster dive for tires with my old car. But now I can find decent new tires so cheap I'm not that worried about it. I've been running 235s with around 30 psi and it grips pretty good on the track. 0 camber and 0 toe, once it's sideways it's gravy, feels like a big heavy boat sometimes.
Freedengineering.com
#362 battleaxe
battleaxe
  • 724 posts
  • Gender:Female
Posted 04 June 2017 - 09:38 PM
Sounds like it's the lack of a sway bar that's your main issue then. That disconnected and loose changing feeling is sway bar related
#363 tuner4life
tuner4life
  • 521 posts
  • Interests:Vehicles!!!
  • Powered By:Caffeine, Dicks
Posted 05 June 2017 - 04:27 AM
Definitely get a rear sway bar. Even if you don't use a huge one, anything will be an improvement over stock.
While on one hand, a large rear bar will make the rear slip less (helps with low power), it will also make everything more stable and flat in drift (read: consistent). These cars feel like a whale without a good rear sway bar. Mine was almost violent during transitions without one.. Grip can be added back in with wider/better tires and other adjustments. I've seen many very competitive and pro level drift cars with huge rear sway bars.
fe92ad35-3c34-44ba-a123-e3699aae7267_zps
#364 Billyhoo
Billyhoo
  • 331 posts
Posted 05 June 2017 - 06:08 AM
Alright sounds like a plan.. haven't been into drifting since back when the cool thing to do was run no rear sway lol. Now I guess they're running big bars and softer springs. Think people use those God peed rx7 bars with some success.
#365 Nigel_Vertigo
Nigel_Vertigo
  • 226 posts
  • Powered By:Alcohol
Posted 05 June 2017 - 07:52 AM
Do not buy the Godspeed one. I put one on my old car when it was stock and it bent on both ends from daily driving.
#366 shlammed
shlammed
  • 562 posts
  • Powered By:Cummins-5.9, Dicks
Posted 05 June 2017 - 09:48 AM
try a speedway bar?
#367 battleaxe
battleaxe
  • 724 posts
  • Gender:Female
Posted 05 June 2017 - 04:29 PM
Try stock and see if it fits and works, then spend money after. Lol
#368 Billyhoo
Billyhoo
  • 331 posts
Posted 05 June 2017 - 06:04 PM
Yeah prolly go that way. FC front sway right?
#369 battleaxe
battleaxe
  • 724 posts
  • Gender:Female
Posted 05 June 2017 - 06:44 PM
no idea. your setup is very different than like anyones on here. the suggestions ppl have made were for a x8 rear subframe. id assume your MKIV frame has spots for a MKIV rear sway? I don't think any of us know what the differences are between the 2 to make any assessment?
#370 Billyhoo
Billyhoo
  • 331 posts
Posted 05 June 2017 - 07:17 PM
Nah it's all x8 stuff. Just welded mounts for MKIV diff
#371 tuner4life
tuner4life
  • 521 posts
Posted 07 June 2017 - 03:26 AM
Yes, the front bar from a FC Rx7 will fit but you will need to beef up the mounting points and move them towards the rear.
FWIW I have the godspeed bar and it hasnt bent after half a dozen events, but I know others have had issues.
#372 Billyhoo
Billyhoo
  • 331 posts
Posted 07 June 2017 - 07:04 PM
Do you have heim endlinks or rubber ones? I'll probably try the stock bar but I'm surprised there aren't more aftermarket options for those cars.
#373 tuner4life
tuner4life
  • 521 posts
Posted 12 June 2017 - 05:59 AM
I used Moog end links but I don't remember the part number. I worked at a parts store at the time and spent most of a shift looking for what I wanted. Also with the extra strain of the big bar, it broke the link mounting tabs off of the Xcessive rear arms. i had to weld on some beefed up versions and move them outward sightly so that the links would be straight up and down..
#374 Gordo
Gordo
    Resident Grumpy Old Man
  • 7047 posts
Posted 12 June 2017 - 08:12 AM
Your kidding, right........
It's a Cressida, not a mushtang.
And stock bar is all but useless.
End links for back, one 3/8" male rod end, screwed into one 3/8" female rod end, done!
Prefixes for 'Gordo'
口 Holy Shit
口That ass hole,
口The Magnificant
口That old fart,
口The infamous
口That crazy
口That 7M guy,
#375 Billyhoo
Billyhoo
  • 331 posts
Posted 12 June 2017 - 09:40 PM
No, I mean rx7s
Thanks for the pic, I figured maybe some squishy endlinks saved your god peed bar but I guess you just got a good one.
#376 Billyhoo
Billyhoo
  • 331 posts
Posted 24 July 2017 - 07:16 AM
Update
Still no paint or sway bar yet...
Got a real body kit, some of y'all already saw it probably
Actually learned of S9 and G from this forum when I got my first x8 in like 07...
#377 shlammed
shlammed
  • 562 posts
Posted 25 July 2017 - 05:52 AM
Kit looks good, I like that its not so common and lets you actually drive without scraping all over the place.  Saw discussion on Instagram of color choice.
Is the grille/front bumper fitment good with the Chaser stuff once you get it fully mounted?
#378 tuner4life
tuner4life
  • 521 posts
Posted 26 July 2017 - 04:35 AM
Looks great!! They really did a good job on that kit design!
#379 Billyhoo
Billyhoo
  • 331 posts
Posted 26 July 2017 - 07:33 PM
Thanks, yeah I've never been a big body kit guy but I think these cars just need em.
Fitment all over is amazing. Especially surprised by the side skirts even on my jacked up car. Headlights and stuff is a little pushed out more than they should be but still lines up pretty good.
