Rav4 struts and strut spacers on mx83 question
13 replies to this topic
#1 MolesterStallone
MolesterStallone
  • 9 posts
  • Powered By:7MGTE, 1UZFE, Cummins-6.7, Dicks
Posted 18 May 2018 - 04:25 PM
I have been searching for hours and have not found an answer, what exactly is the 7mm strut spacer needed to do the rav4 front struts and where does it go? What is it's purpose? Does it just go under the strut tube itself to ensure it bottoms out in the lower mount for the knuckle? Getting ready to do the rav4, ma70, and s14 combo and wanna make sure I have everything right and ready to go. Sorry if this is hidden somewhere on here already but I definitely couldn't find it.
Also the threads I have found give a non existing part number for the rav4 kyb struts. This is an issue because apparently the 4door with 16" wheel rav4 and the 2 door with 16" wheels/4 door without 16" wheels have a different length shock (two seperate sets of part numbers). So would anyone also know which option of the shocks is the one to use?
#2 Gordo
Gordo
    Resident Grumpy Old Man
  • 7450 posts
Posted 18 May 2018 - 05:37 PM
When you figure it out, let us know, and post pictures.
(are you capable of posting pictures?)
Hint: Buy both, take the set that doesn't fit back.
Prefixes for 'Gordo'
 口 Holy Shit
口That ass hole,
口The Magnificant
口That old fart,
口The infamous
口That crazy
口That 7M guy,
Best JZXP statement:
#3 Nigel_Vertigo
Nigel_Vertigo
  • 274 posts
  • Powered By:Alcohol
Posted 18 May 2018 - 06:02 PM
Never even heard of doing this before. Unless you can get the parts for near free though, I'd just put the money towards proper coilovers.
#4 MolesterStallone
MolesterStallone
  • 9 posts
Posted 18 May 2018 - 06:31 PM
I answered my own question finally, since you posted you have never heard of this I'll explain the whole set up. Our OEM struts are rebuildable, you can undo a threaded collar and remove the guts of the shock. So for the front you buy a strut insert for a 96-00 rav4 that drops into your original shock tube, not a complete strut. You have to put a 7mm strut washer under this within your lower original shock tube for it to work as these inserts are 7mm shorter than the original Cressida ones. Your original Cressida top hats also work with these inserts. These Rav4 shock inserts are approx 50% stiffer and have about an inch less shock rod height for much better use and ride with lowering.
The ma70 kyb rear shocks can have the lower perches swapped from your original struts and also use your original top hats with the hole slightly enlarged through them. These struts offer about the same 50% stiffer and inch less rod height for less of the shock travel lost when lowered.
Finally, OEM s14 springs are a direct replacement for your factory Cressida springs and give you about 2" drop front and 2.5" drop rear. When combined with the above shock set up it makes an extremely affordable suspension upgrade i.e. kyb strut inserts are about $42 each, rear kyb ma70 struts are about the same at just over $40 each, and a used set of s14 springs can be had for next to nothing.
#5 Gordo
Gordo
  • 7450 posts
Posted 18 May 2018 - 06:59 PM
We don't care........
This is all shit that was happening 20 years ago.
All you are ending up with is a cobbled together car that sits low, without the spring rates, or dampening that a low car requires, so it handles like shit.
In other words, facebook crap.
Did you graduate from some fucking Datsun?
Most Datsun owners can't think past building a 'tuner car' from junk yard shit.
 口 Holy Shit
口That ass hole,
口The Magnificant
口That old fart,
口The infamous
口That crazy
口That 7M guy,
#6 MolesterStallone
MolesterStallone
  • 9 posts
Posted 18 May 2018 - 10:49 PM
If I'm not mistaken, in my searching I seen you had an ma70 set up in the rear of one of your cars that "worked so good"...
#7 Gordo
Gordo
  • 7450 posts
Posted 19 May 2018 - 02:02 AM
20 years ago.
It was too soft, too little dampening.
 口 Holy Shit
口That ass hole,
口The Magnificant
口That old fart,
口The infamous
口That crazy
口That 7M guy,
#8 Jason
  • 5148 posts
Posted 19 May 2018 - 03:33 AM
And you're still stuck with shit sized wheels because the spring perches are huge and don't allow clearance for wider wheels and tires. I'm rolling on a set of 25 year old TEINs. I'd sell them for about what it cost you to cobble that shit together.
#9 Jacob
Jacob
    All the things
  • 2383 posts
  • Gender:Not Telling
  • Country:Antarctica
Posted 19 May 2018 - 03:52 AM
This is all well documented on TC.net
May be you'd be happier over there
No.
#10 Gordo
Gordo
  • 7450 posts
Posted 19 May 2018 - 06:20 AM
If all you want to do is putz around town with a stock 7M, then go for it.
The car won't handle anywhere near it's potential though.
Don't come on here, and brag about it, because there is nothing to brag about.
When I tried it, I later switched to 65mm springs on it, and you just can't get dampening stiff enough, and have to limit spring rates to keep the thing from pogo sticking down the road.
And if you go to the remains of the TC.net crowd, Cressida Forums, you may bring some life back to the place.
Many sections over there have not had a new post in them for YEARS.
Probably because most of them hang on facebook, and call it a forum.
Again, if you can't even figure out what strut cartridges you need, you are doomed, and so is your car.
JZXP isn't for people who want hand holding on doing stuff wrong.
It's more about doing stuff right, or trying to do stuff better, without hand holding, then posting it up for all the facebook guys to see.
 口 Holy Shit
口That ass hole,
口The Magnificant
口That old fart,
口The infamous
口That crazy
口That 7M guy,
#11 MolesterStallone
MolesterStallone
  • 9 posts
Posted 19 May 2018 - 10:24 AM
Jesus, I got a good deal on some wheels and tires and just wanted a cheap, more legit fix than cutting springs or something similar. Coilovers are 10000x better obviously, I won't argue that. I'll buy a set when I care about this car more than renoing my house and finishing my other cars. But at this time I'm just wanting to reduce some wheel gap safely and on the cheap so my work beater/ grocery getter doesn't look goofy. When I swap the car and start actually getting serious about it, coils it is, just wanted some clarification that searching wasn't providing me. I dunno how I'm bragging? It's quite clearly not the best option but will work. Some people may actually care to do it for the time being such as yourself "20 years ago" (more like 5) Gordo. Regardless I figured my original question out, thanks guys.....
#12 battleaxe
battleaxe
  • 923 posts
  • Gender:Female
Posted 20 May 2018 - 11:51 AM
when i read the thread title,  i was hoping for a lifted cressida with bigger wheels and tires. i was disappointed. :(
#13 Gordo
Gordo
  • 7450 posts
Posted 20 May 2018 - 03:21 PM
I want a JZX93 !
4-wheel drive with big tires on the mother !
 口 Holy Shit
口That ass hole,
口The Magnificant
口That old fart,
口The infamous
口That crazy
口That 7M guy,
#14 ChriSOL
  • 7039 posts
Posted 20 May 2018 - 05:07 PM
guys.
