Sep 5 2006, 09:45 PM
Post
#41
![]() I HATE 7M Group: New Members Posts: 54 Joined: 4-September 06 From: Renton, WA Member No.: 308 |
so how was it then?
Sep 5 2006, 09:57 PM
Post
#42
SMOKEY Group: OG Posts: 2,543 Joined: 7-May 05 From: New Jersey (southern) Member No.: 53 |
QUOTE (vampirebeats) so how was it then? its was running a 7mge then. check the video -------------------- QUOTE (brian) a puppy in a hot car lasts longer than a 7m. |
Sep 13 2006, 07:37 AM
Post
#43
I♥1J Group: New Members Posts: 453 Joined: 19-October 05 Member No.: 124 |
nice swap... kinda reminds me of transsexuals and their sex change operations... it can be done but it never quite looks right...
-------------------- c33-- JZX's red-headed evil stepchild
kumasan616@hotmail.com ![]() |
Sep 13 2006, 09:27 AM
Post
#44
![]() I♥2J Group: real members Posts: 2,327 Joined: 15-November 04 From: muthafuckin Torrance Bitch!, CA USA Member No.: 20 Country:
as long as rich doesn't paint it bright yellow...
-------------------- ![]() 1989 Toyota Cressida: 1JZ-GTE HKS T300 Single Turbo 1988 Toyota Supra Turbo beater (unfinished) BellHelmets.com Special helmet deals for JZXP members in 'Private Eyes' |
Sep 13 2006, 09:31 AM
Post
#45
QUOTE (Hydra) as long as rich doesn't paint it bright yellow... aww damn it..... i just got started on painting it. now i have to change the color haha.
Sep 13 2006, 08:50 PM
Post
#46
I♥1J Group: real members Posts: 894 Joined: 21-July 05 From: U.S.A Member No.: 80 |
bently black !!!!!!
Sep 17 2006, 04:06 PM
Post
#47
i wish i hadnt forgot my camera at home.
Sep 18 2006, 09:47 AM
Post
#48
Below is one of my reasons for using a SR20DET in my cressida. I saw pictures of this car in Option about a year and half ago. Originally I was wanting to do a 3sgte but because the 7mge went out in the beginning of the season I needed a motor that was a complete motor, trans, ecu, harness setup withh out looking all over for other parts. This cemented my decision to screw the purest idea of keeping it all Toyota or going withh the bigger 1jz.
_________________________________________________________________
The super chaser of the real dream which was announced at Tokyo automatic salon of this year, called topic. It pursues lightness, loading more lightweight compact SR20 than 1JZ. It removes any which either the body make-up is not [hanpa], there is no necessity wearing once to a complete [dongara] state entirely, the how car is squeezed weight to 1200kg. There is a reason only of the real dream where it knows JZX to here and exhausts that you adhered to light weight conversion. As for 1JZ certainly good engine. Durability is high and, you can aim even 800ps over withh tuning circumstance. So, the shop you challenge to the Tsukuba 1 minute cutting withh 1JZ so far many, still being able to achieve it is not present condition. If the technical course the Tsukuba way is designated as the stage, depending in just power, there is a limit. That compared to 4 door sedan largest weak points, it judged as deciding beforehand that weight is overcome very. And, from the result which marks the Tsukuba 59 second level withh S15 of the time before 400ps, there is also know-how, decides the swithch to light SR20 withh aluminum block of 4 cylinders passing, reason. So, but concerning the running which becomes matter of concern this time attack does not become because setting still has not finished taking. Because of that potential whether Akira it was not possible to do, but is because the target time calls 57 second level which furthermore exceeds 59 seconds, the [tsu] [te] which can be expected it is. It keeps finishing the December this year super lap in goal, because so is, it reports in detail that time concerning running.
Originally because 4 cylinders are placed in the place where 6 cylinders are loaded, room is born space. To tell the truth substantial processing is not administered to the bulkhead and the [te], also the fact that is, to front midship it can convert, the reason which decides the conversion to SR20. The engine is converted, to 2.2L installing the K5-660R turbine. Still, but setting stage it is the specification, 550ps withh the boost 1.5kg/cm ². -------------------- QUOTE (brian) a puppy in a hot car lasts longer than a 7m. |
Sep 20 2006, 11:35 AM
Post
#49
![]() I♥1J VVT-i Group: Root Admin Posts: 3,092 Joined: 5-September 04 From: Phoenix Member No.: 2 Country:
oh the humanity.
-------------------- That rug really tied the room together, did it not?
| Guest_Push_* |
Sep 20 2006, 02:47 PM
Post
#50
Guests |
your car run yet???
Sep 20 2006, 09:14 PM
Post
#51
I HATE 7M Group: New Members Posts: 252 Joined: 31-August 05 From: the bronx Member No.: 98 |
THIS IS BLASPHEMY AT ITS PUREST FORM I HOPE YOU DRIFT IT INTO SIDE RAILING!!! jk looks good though a 3s woulda been much sexier. nycressida = nissan hater!
-------------------- george
Sep 20 2006, 09:15 PM
Post
#52
makes me want to swap out my 1j and go withh a 4agte.
Sep 20 2006, 09:33 PM
Post
#53
QUOTE (nycressida) makes me want to swap out my 1j and go withh a 4agte. tu es loco.
Oct 9 2006, 06:31 PM
Post
#54
UPDATE: The wiring is coming along. We had lights, blinkers, dash lights, stop lights, and heater motor working. Today I received a call and it also cranks over. Should be running this weekend and I should have it home by next weekend. Still need to totally figure out what to do for powersteering lines. I have the 240 lines but the ends do not reach the rack and they are the wrong threads. so the return line is an easy fix since i just need to get a long hose for the toyota fitting to the 240 reseviour but i need to get the toyota end mated to the 240 hose for the high pressure side.
Oct 10 2006, 01:53 PM
Post
#55
simple... call earl's or baker or whatever plumbing fab shop you like and tell them what you need, they can fab one up pretty easily...
Oct 10 2006, 05:05 PM
Post
#56
QUOTE (kumasan616) simple... call earl's or baker or whatever plumbing fab shop you like and tell them what you need, they can fab one up pretty easily... word, i'll have to give them a call.
Oct 12 2006, 01:10 AM
Post
#57
HA A HA A HAHAHAHHAA!! wow, even though my car is still kind of beat looking, it sure has come a long way. -------------------- QUOTE (brian) a puppy in a hot car lasts longer than a 7m. |
Nov 19 2006, 08:41 PM
Post
#58
it runs. not 100 percent finished but its driveable. needs some tuning/timing done but its fast as is.
i have a crappy little video here http://vids.myspace.com/index.cfm?fuseacti...eoid=1449068523 -------------------- QUOTE (brian) a puppy in a hot car lasts longer than a 7m. |
Nov 20 2006, 02:48 AM
Post
#59
rich is back in the game
Nov 20 2006, 03:49 AM
Post
#60
![]() cressidas are for sissies Group: Administrators Posts: 2,196 Joined: 8-September 04 From: 0ttawa 613 Member No.: 3 Country:
the new wheels are neat.
too bad winter is coming I wanna see it in action like yesterday. -------------------- Bill | DeathBySedan.com | Don't tell me, I'll tell YOU!
| Lo-Fi Version | Time is now: 10th September 2010 - 07:26 AM | |
| Design and Concept by Attitude Valid XHTML 1.0 Transitional |
