Dec 20 2008, 08:15 PM
Post
#301
SMOKEY Group: OG Posts: 2,543 Joined: 7-May 05 From: New Jersey (southern) Member No.: 53 |
just a pic i finally took of the cheap steering while I bought off of ebay.
-------------------- QUOTE (brian) a puppy in a hot car lasts longer than a 7m. |
Dec 20 2008, 09:10 PM
Post
#302
FREE CANDY Group: Administrators Posts: 3,099 Joined: 15-November 04 From: Philly-side Member No.: 21 |
woah rich! welcome to 2003!
-------------------- Virginia may be for Lovers, but Pennsylvania has Intercourse!
Dec 20 2008, 09:38 PM
Post
#303
I♥1J Group: real members Posts: 517 Joined: 25-August 06 Member No.: 302 |
Good man. I know it's cheap but wayyyy better than what you had going. How do you like the position with the much deeper wheel?
-Matt-Panic! |
Dec 21 2008, 09:23 AM
Post
#304
I will have to play with the postion once I am driving the car again but There is plenty of movement in the colum to push it as far back as needed or to pull it closer then what the stock wheel can be moved. So it does allow for a great range of movement so you can fine tune the postion. I will say that I am happy with my seating postion but will try the wheel closer and see how that works out. I can also get some leg clearance now and tilt it down more since the will is smaller.
Dec 22 2008, 11:42 AM
Post
#305
I♥1J Group: New Members Posts: 366 Joined: 11-December 07 From: VanCity, BC Member No.: 1,807 Country:
just a pic i finally took of the cheap steering while I bought off of ebay. ![]() Are you referring to the monster tac? lol Not trying to hate, but do you actually find the position of those gauges useful? Looking at your passengers feet everytime you wanna check oil pressure doesn't make sense. I assume they are gauges that don't need to be checked often? -------------------- ![]() |
Dec 22 2008, 01:06 PM
Post
#306
oil pressure is in the middle of the consoled along with water temp. all 7 were given to me for free when i was on a team and I had to put all of them in. EGT fuel pressure and an extra water/oil temp are on the right. The fuel pressure is the only one that is actually hooked up on there. Boost gauge and volt meter are on the top of the dash. I would never pay money for those gauges.
May 13 2009, 03:57 AM
Post
#307
lowered the car one mor einch in the back because that is as low as the coil overs will go.
![]() Totally in hate with this car. -------------------- QUOTE (brian) a puppy in a hot car lasts longer than a 7m. |
May 13 2009, 04:35 AM
Post
#308
somebody needs 18s.....
May 13 2009, 07:24 AM
Post
#309
i need powersteering and a bunch of other things before i worry about rim size.
May 13 2009, 11:33 AM
Post
#310
![]() I♥1J Group: real members Posts: 377 Joined: 25-February 08 From: south city, norcal Member No.: 1,839 Country:
wow i'm liking the way your car looks all beat right now. what wheels are those, they actually look decent painted green? and not black.
May 13 2009, 03:15 PM
Post
#311
All i know is the name is DrifZ. dont know the model name. I want to pull all the decals off and just spray paint with a stencil MISSLE STATUS on the sides in the same Italian olive green that I painted the rims.
May 13 2009, 07:45 PM
Post
#312
ill never let you park next to me if you do that.
May 14 2009, 04:06 AM
Post
#313
i dont want to park next to you.
I don't think this car will ever look good. What I mean is, I have no intention of making it look good. Just keep smashing it up until I can swap shit over to another shell. Maybe in 2012, when cressidas with blown 7Ms go for $2000.......... -------------------- QUOTE (brian) a puppy in a hot car lasts longer than a 7m. |
| Lo-Fi Version | Time is now: 10th September 2010 - 07:33 AM | |
| Design and Concept by Attitude Valid XHTML 1.0 Transitional |
