475 replies to this topic
#461 LUMBERZACK
LUMBERZACK
  • 353 posts
  • Powered By:7MGE, Dicks
Posted 17 September 2018 - 04:33 PM
If you're like me and live in a hot ass climate year round, you probably thought about bypassing the heater core. Well look no further. The inverter hose for a Lexus HS250h works perfectly as a heater core bypass hose on the 2JZ when going to single turbo. Part Number G9225-75010. Unless you know someone that works at the Lexus dealership that can get you the $30 dealer cost, you may want to sit down for this because Lexus retails this hose at $73..
Fortunately for all you broke boys with less fortunate personal connections, this hose cross references with Gates 18022.
#462 Lofty
Lofty
    MOTOBYTE.NET
  • 2163 posts
  • Country:Uganda
Posted 18 September 2018 - 10:59 AM
Good find I like it.
#463 Gordo
Gordo
    Resident Grumpy Old Man
  • 7421 posts
Posted 18 September 2018 - 01:24 PM
Not sure if that is a good idea....
When the heater is in the circuit, and you are running the heater (cold weather), the water is being cooled by the heater core before it goes back to the water pump.
When the weather is hot, and you are not running the heater, the flow is blocked by the valve, and not returning to the water pump.
So now, you are running hot water directly back to the water pump, in hot weather.
Good luck with that.....
Prefixes for 'Gordo'
 口 Holy Shit
口That ass hole,
口The Magnificant
口That old fart,
口The infamous
口That crazy
口That 7M guy,
Best JZXP statement:
#464 WhoreMouth_Jr
WhoreMouth_Jr
    I ♥ 1.5J
  • 2905 posts
Posted 18 September 2018 - 02:26 PM
Where does the water go in the case the heater valve is closed.
#465 Gordo
Gordo
  • 7421 posts
Posted 18 September 2018 - 02:36 PM
It just stops.
 口 Holy Shit
口That ass hole,
口The Magnificant
口That old fart,
口The infamous
口That crazy
口That 7M guy,
#466 WhoreMouth_Jr
WhoreMouth_Jr
    I ♥ 1.5J
  • 2905 posts
Posted 18 September 2018 - 03:21 PM
Right so that path would fill up and stop, but the flowing water has to go somewhere.  I can't find a diagram of how the water flows through the head, but I imagine if it's not flowing out that rear port it will eventually find it's way back to the water pump anyways?
*edit* I must be just thinking about this wrong.  Thinking the hot water going the water pump is going to the rad, but it's probably going back into the engine which would make sense.
#467 Gordo
Gordo
  • 7421 posts
Posted 18 September 2018 - 05:14 PM
Bingo....
 口 Holy Shit
口That ass hole,
口The Magnificant
口That old fart,
口The infamous
口That crazy
口That 7M guy,
#468 LUMBERZACK
LUMBERZACK
  • 353 posts
Posted 19 September 2018 - 01:31 PM
Good call Gordo. I researched this a ton. 10% of Supra guys said to cap the nipples and the other 90% said to bypass the heater. I shouldve looked at a coolant flow diagram because after looking at the diagram, I can tell that if I cap it, it would be more beneficial since it will force coolant to the radiator. Ill probably just cap them and if I feel its a good solution, Ill crimp and tig the tees closed.
#469 Gordo
Gordo
  • 7421 posts
Posted 19 September 2018 - 02:30 PM
Since you already have the hose, and if you can't return it, just push a large ball beating into the end, and leave it.
Or just have someone weld a cap on each nipple, but it kind of fucks it up (just like crimping the ends over) for if you ever want to use the defroster.
I've seen a lot of SCCA cars that wish they had kept the heater core, and defroster option, when they have an event in the rain, and their windshield fogs up.
But they saved 3 lbs of weight.....Woopy ding dong!
I've made machined plugs before, used with a short length of hose, but that still looks crappy.
I wouldn't use the rubber caps they make for closing off nipples, as they don't have any fiber, or cords in them, and I've seen them burst.
 口 Holy Shit
口That ass hole,
口The Magnificant
口That old fart,
口The infamous
口That crazy
口That 7M guy,
#470 WhoreMouth_Jr
WhoreMouth_Jr
    I ♥ 1.5J
  • 2905 posts
Posted 19 September 2018 - 02:46 PM
^^ To add on I've seen a ton of jz people just put a cap and clamp on the extra waterpump nipple when going single turbo.  And those eventually fail and leave them on the side of the road.
I wish I had mine welded, but I ended up finding a better material cap then the checkers crap.  And it's held up fine so far.  Only downside was it was like minimum 100 order
#471 Gordo
Gordo
  • 7421 posts
Posted 19 September 2018 - 04:58 PM
Frost plugs, of the correct diameter, that sit over the ends of the tubes weld up nicely.
 口 Holy Shit
口That ass hole,
口The Magnificant
口That old fart,
口The infamous
口That crazy
口That 7M guy,
#472 LUMBERZACK
LUMBERZACK
  • 353 posts
Posted 19 September 2018 - 06:39 PM
I could just hook up the lines to the heater core. Lol but I kinda don't want to. It rains maybe 9 days a year.
I didn't buy the hose actually, this was info from a friend who found out the hose worked. I ordered the hose from Lexus, but I haven't picked it up.
Yeah I hate those rubber vacuum caps. They barely work as vacuum plugs, let alone anything with heat and pressure. Part of me just wants to tig them shut, but the other part of me wants to clamp a short hose with a machined barbed plug to save for future use. I guess bypassing the hose was an easier decision lol.
#473 Demesio
Demesio
    I♥VTEC
  • 1451 posts
  • Country:China
Posted 19 September 2018 - 08:43 PM
I welded mine AFTER that same thing happened...
#474 LUMBERZACK
LUMBERZACK
  • 353 posts
Posted 20 September 2018 - 06:02 AM
Demesio, did you weld a round cap or crimp the end and weld that?
#475 Demesio
Demesio
    I♥VTEC
  • 1451 posts
  • Country:China
Posted 20 September 2018 - 08:19 AM
crimp and weld.
I only did the turbo one, i have a working heater and A/C.
#476 battleaxe
battleaxe
  • 907 posts
  • Gender:Female
Posted 20 September 2018 - 08:47 PM
we cut and welded the stainless water line there to go from the back of the water pump to the heater core then back, i took off the cold side that fed back to the TB. the nipples on the water neck were welded and ground as well. used one for the water temp sensor and with the billion thermo my temps are sub 85C and peaks at 90C after hot lapping so im keen on that. i have a non vvti 1jz though so i know theyre a bit different.  as i run a borg i dont have water cooling either
